JoelF
I am in the process of replacing an intake. I'd like to access the core plugs in the block to get all the old coolant out of the block. My question is this: will there be any damage to running the engine with no coolant or water, if only for a few minutes?
I am mainly concerned about damaging the water pump by running it dry. The reason I would like to run the engine in this state is so that I can put the car on ramps to get access to the core plugs. I would probably start the car, back it up, position the ramps, then drive up on them and shut it down.
Possibly I'd restart the car and pull back off the ramps after removing the plugs so that the engine is again in a level position, shut off and allow to drain fully, then restart and pull back on to replace plugs and button up the system before refilling.
Thoughts?
Thoughts?
