Greetings, Fix one problem on this car and find 3 more!
I have a 1974 Corvette that had the "traditional" hard start problem when hot.
I changed the starter with a mini-starter and a heat shield and that seemed to fix the problem.
I also converted the old points distributor with a new mallory unilite distributor. I used the ballast resistor and wired everything correctly.
The car runs great. The problem is it takes a lot of cranking to start. At times, im not even sure it will re-start. I can see there is fuel in the filter (its transparent). The new starter only had the "S" terminal. THe "R" terminal is not being utilized and i left it disconnected.
Also, whats strange is that when cranking...if you let a little pressure of the key...it will start. If you hold the key down...it cranks and sometimes will start.
Will a bad ignition switch cause this problem?
Sorry this message got a little long...but, at this point ive really had it!
Thanks in advance for the help! Mike
