My 88 starts and immediately quits running. It will do this 2 to 6 times before it will start and continue to run. Once its running, everything seems fine. Runs strong, no miss or hesitation. Shut it off, leave it sit for a while and the problem is back. Fires right away when started, then quits. No codes in ECM. I'm guessing it may be throttle position sensor or coil but not sure. Any ideas? Any help would be appreciated.
