Steering column on a 66
IH2LOSE
We Will All Meet Again
1966,and a 1962 thats almost complete
So I collected the parts I think I need to rebuild my steering column. I thought there was a post on this last year or the year before and thats where I got my material list from.
Any ways I plan on rebuilding the steering column this week end and just looking for any advice you may want to share.
Steering
I did my 66 a few weeks ago after powder coating most parts. The rebuild is pretty straight forward. There is a procedure for putting it back in the car which must be followed. I remember reading a post by John Z about it. Even though I rebuilt my column, I have yet to put it in my car. Jerry
Steering
Yes, that is the post I was thinking about. It was a great help to me. I just got my Z's mixed up. Sorry. Jerry
Yup, Dave (Zuberer) does a terrific job annotating photos with text - really makes DIY projects a "look-and-do-it" proposition! I have yet to find a "simple" software package to do that (which shows how "simple" I am) :)
Thanks guys. Now I'm blushing! Appreciate the kudos. Appreciate even more all the help you guys have given to me and the friendship that has grown out of it!
:w
Dave Z
Well I got my column out and it was tore up.
I will post some photos tonight. My original problem was I could wiggle the steering wheel side to side.
What I found was the entire end of the column housing was gone where the signal housing mounts.
after I removed the steering shaft from the column jacket I found the steering shaft had been welded and poorly machined in the area the lower bearing rests.
So I need to replace the shaft as my lathe is not long enough to for me to re-weld then re-machine it.
So for now I have to order a new steering shaft but I do have some questions.
How do I know where to set the new shaft do I just remount every thing and let the steering wheel position set the shaft and then tighten down rag joint to hold it in place.
Next the turn signal housing has a recess in it for a screw or a bolt to go thru it but there was nothing in it when I started to disassemble it nor did I find something for it to screw to
Also what position should the recess on the steering column sit mine was at 9 o clock with nothing attached to it
I am also trying to repaint
the steering hub
the signal housing
the escution
I cleaned them up in my blast cabinet, Wiped them down with denatured alcohol then primed with east woods self etching primer "dry coats" and its fish eyeing on me . Every thing from my interior I have ever tried to repaint fish eye's
Larry
Sounds like you are going to need a new mast jacket as well as the shaft. Here are some pics that should answer your questions.
JohnZ indicates that the index marks are all supposed to be at 12:00. Alignment shops frequently take short cuts like you see in the picture of the marks from my 65.
If I have neglected something here, don't hesitate to jump in fellow forum members!
Hope these help.
DZ
I know it's a hard habit to break, but the (very typical) broken/mangled tabs on the jacket are the result of using the steering wheel as a hand-hold to get in and out of the car. I have to remind myself every time NOT to do that. :)
John I honestly think I tore it up by power shifting the car.
HA HA
I know the prior owner of my car was a biggen as the seat was completey flattened.As I re checked the column mast I can see some body had treid to weld it in the past.
Yup you are correct should not use the steering wheel as a handle to get in and out of the car.
Well I have the column back in
New column jacket
New steering shaft,
new upper bearing
new lower bearing
But I still have movement,as a matter of fact it feels like the same movement I had prior to replacing every thing
I can move the steering wheel from like 4 o'clock to 11 o'clock about a 1/8" to a 1/4" (not rotational movement but a vertily movement that you see the blinker housing moving )What could I have done wrong or is this normal movement's seams as though the upper bearing is allowing the movement
I loaned out my steering wheel puller so I have to take it back apart tomorrow. I have to tell you you pictures helped a lot
I also took the time to replace my worn clutch pedal and replace the bushing in the brake and clutch pedal assembly
