LanceB
I am replacing my 1975s stereo with a new CD player. I have my new harness and everything seems pretty straightforward. The harness wires and colors are all the same except what I am seeing for the red and the black wire. The current harness' black and red wires go into a little black box (this box is unmounted) and then they exit the box. I don't see the black wire grounded anywhere behind the stereo. This box will not open for the life of me but I think it has to be either an engine noise suppressor or breaker. There is a fuse for the red wire already (after this red wire exits the box). I would just wire the harness the exact way except the new harness black wire has a fork on the end of it and says it should be mounted on the chassis. I have a good area of chassis to do this but my question is if I should tie that current black wire going into this box in with where I ground the new black wire (with the fork) on the chassis?....so basically the same wiring scheme that worked for the old cassette player/harness should be done? Any advice appreciated! :confused
