Subfixer
I sent my aluminum intake and cast exhaust manifolds over to Jerry MacNeish's for reskinning, so to pass the time I thought I would fix the slow headlights... Bubba was here too.....
The left motor assembly is correctly date coded for the car (10/63), and aside from needing cleaning and lube, was in good shape.
The right motor assembly was from a 67 (1/67) and had obviously been apart before. The motor bronze bearing (at the end of the motor shaft) was all scored up on it's ouside, the retainer spring and the spring retainer plate were both missing from the motor body and the manual operation wheel retainer clip was missing.
Then I moved onto the headlight housings themselves. They were pretty stiff when I started and here's why..... All the Brass-steel bearings were seized onto the bucket pivot shafts, so what did Bubba do? He greased the ouside of the bearings so they would be able to spin inside the support cups.... I had to cut the bearings off the shafts.
Well, more parts are on order now to fix this mess, but at least my headlights will go up and down as they should. It's always something....
