MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
As you may remember, I need a new hood.
So, I have the one option of looking around for a used (stock) hood, which is probably the cheapest way to go, unless it ends up needing any work to get it right...
And the other option is getting an aftermarket hood. Having seen several in person, I do fing myself really liking the look of the "stinger" hood on the C2's. I've seen these hoods for C3's, and they look good in pictures, but I've never actually seen one in the flesh. At $450 or so (Vanacor), it's a bit more expensive than a used stock hood, but if I'm going to replace the hood anyway, I'm seriously considering either something like this or an L88 hood.
I'm curious if the scoop is functional (open)? I've seen some that are filled, and others that are open - does anyone know which is the case with this hood?
If the scoop is open, does anyone know where the it is located, front-to-back? I'm curious exactly where the airflow would be entering, in relation to the air cleaner location.
Will this hood clear an Edelbrock Performer AirGap manifold? I may go with that manifold when I re-do the engine, and I want to make sure it will fit.
Finally, is the quality there with these hoods?
Joe
Joe
