1969 Corvette Stingray:
The 1969 Corvette was unique in many ways. Since this is the second year for the new body style the spelling for Sting Ray has changed to one word, the name presumes from previous years. Note 1968 was not called Stingray. New door handles are squeezed down to open the doors. The doors are also longer in dimension. First year for ignition key to be relocated to steering column with locking mechanism feature. Base engine increases in displacement from 327 Cubic Inches to 350 Cubic Inches. This is the last year for availability of the Big Block engine 427 Cubic Inches. The last year for the 427 L-88,and Tripower carburetors. First year and only year for all aluminum 427 Engine ZL-1. There are only two ZL-1 engines that were factory installed with supporting documentation. Estimates are in excess of 600+ Horsepower for ZL-1.
Production Figures
Coupe: 22,129
Convertible: 16,633
1976 Corvette Stingray:
This was the last model year for the Stingray. Corvette for 1976 was no longer available in convertible body style. Coupe was available with the removable roof panels (T-tops). The Big Block 454 Cubic Inch engine was no longer available, as of model year 1974. There were two versions of the 350 Cubic Inch Small Block V-8. The base engine was code L-48 rated at 180 horsepower. Optional V-8 350 Engine was code name L-82 rated at 210 horsepower.
Other changes include the use of "New Freedom" Battery, a maintenance free car battery requiring no water. New sport steering wheel was the same as used in Chevrolet Vega's. Aluminum wheels YJ8 option code included 4 wheels, and 1 steel rim for the spare tire. Vents on the rear deck which was part of the Astro Ventilation system were discontinued. An engineering change was a partial steel underbelly in the front section to enhance rigidity, and keep the cockpit cooler. This was also due to heat that was generated from the engines designed to run hotter. Hotter running engines was essential to increase efficiency and offset emissions related power loss.
Production Figures
Coupe: 46,558
Total: 46,558
Sting Ray: The original Sting Ray Prototype was produced in 1958. Sting Ray production started with the Model Year in 1963, available for the first time in both Coupe and Convertible body styles. The last year for this body style is 1967.
Stingray: This is the second series in the Stingray body. 1968 Model Year was an all new body. This Model featured removable roof panels, also known as T-Tops. The name Stingray resumed again for the 1969 Model Year through 1976.
