M
Macgyver
After all the adjustments made to the carb Im figuring that I would need to adjust the timing. Ill let you know now that I know jack about the distributor except the concept of it. Here are my questions.
What is the stock distributor that comes on a 81'? Is a good one or should I replace it? If its good what can I do to improve it? Can you use a recurve kit on it?
Whats the difference between the stock distributor and an HEI distributor? Is there much to be gained by using this modification since they do seem to be somewhat expensive?
I was getting Feet/Gallon and after the carb rebuild Im now getting about 10miles pergallon. Will these changes maybe bump that up about 3-4MPG?
One last question, wheres the computer diagnostic hook up?
Thanks in advance for your imput.
Steve'O
Steve'O
