Stock Ignition Shielding
spleen
Lancaster County, PA
None yet, but working on it.
Hi there.
I'm working on a 1:25 scale 1963 Sting Ray with a 327. I've been looking at reference pictures to get a better idea of how a stock engine compartment looks. However, I've seen several versions and I'm not sure which is the most stock/original.
I've seen some pics with no ignition shielding and some with 100% shielding from the plugs to the distributor and varying degrees in between.
I'm trying to build the most popular stock version of the '63 so which shielding option should I be using?
I like the looks of this fully shielded version and I thought it would be fun to build, but I want to be as correct as possible.
Thanks for your help.
Dean J.
Oh, I was going to ask about the air cleaner cover also. Should I use chrome or black for my stock version?
Thanks again for your help.
Dean J.
ALL CORVETTES came with ignition shielding from the factory. Most people removed it because it was a pain to set the distributer, and it was still considered excessive weight.
Air cleaners, the L75 had duel snorkel with Chrome top, the stock 327 had black top and the L-76 had a different cleaner all chrome with no snorkels...exposed elements. So it depends upon the engine you are putting together. Stock with 250HP, L-75 300HP
(came in black and chrome LIDS only), L-76 Chrome open air cleaner.
Best thing to do is get a catalog from Corvette America, Corvette Central, ZIP and see for yourself the options. Engines were different (valve covers, air cleaners, fan/alternator,cranks, idlers..etc)
Hope this helps..
EBvette, radio delete cars and those before when the radio was standard equipment did not have the shielding. The shielding was only for radio interference... Dave..
