SNKSKNR
New member
I have a built 1996 LT4, that I have had since day one. I now have 100,000 miles on it......
11.9 @ 121 best ET. on street tires..... 11.8 @ 126 with 75 shot, turning the NOS off 3 times, not to smoke stock clutch....
Stock block/crank/rods
SRP pistons 12:1 compression
Comp 306 cam
Full length long tubes/no cats/3 inch duals/flowmaster mufflers
my heads, fully worked 2.02/1.60 valves, pro. mag. rockers
my intake ported to match heads and TB
58 mm TB
ported MAF
36 lbs injectors
255 L/Ph SVO injectors
tuned stock OBDII ECM
stock clutch
real ZR1 wheels/rears widened from 17x11 to 17x13 for my Kumho V700 335/35's
stock tranny
that's about it.... very happy with the car!
who else has a pretty fast stock stroke LT4 out there?
-Brian
Comp 306 cam
58 mm TB
ported MAF
36 lbs injectors
stock clutch
stock tranny
-Brian
