STOPTECH Brake Setup-Amazing!
y2khardtop
NC
I can't begin to describe how great the STOPTECH system works. For $2595, you get a front 14" rotor/4-piston caliper system that is truly matched to the Corvettes braking system. No vehicle mods, no add-on bias valves, just bolt on the Calipers and go. Stoptech also uses at patented bridge re-inforcement that makes these calipers extrememly strong. And although the general style of the caliper is very similar to the Porsche/Brembo caliper, the patented bridge and offset-piston layout makes this a great performing setup.
Give these a look if you are in the brake market!
