Strange clicking from rear hatch......
  • Thread starter Thread starter hdcwagsvette
H
hdcwagsvette
For some reason my 84 vette started making a clicking sound from the rear hatch. It wound up killing the battery, so I had to pull the fuse to stop it. Do you think this is the hatch switch, relay or some kind of wiring problem?;shrug
Sounds like one of your hatch switches (probably one of the rocker switches in the door) is not returning to the "open" position when you release it.
My driver's side door switch does this...if I just push it to open the hatch and let it go...the solenoid for the hatch will just continue to cycle. I have to manually push the switch back to the "open" position.
Bill
father & son
Switch,In door!!!!
Had same problem, you should have got to the forum befor your battery died!!
Don't have aneurysm, it's OK.
As I said I pulled the fuse. I also recharged the battery. Thank you for the reply and LIGHTEN UP A BIT :beer
Thank you Bill (Geekinavette), you were correct, I never used the switches in the door and the drivers side one was broken. Thank you for being so polite.
