N
novafink
Hi all,
I took my 96 lt-4 for a ride today and it ran great, when I got home I let it sit for about half an hour, and it would not start. The dash lit up just as it does normally, the battery light and the brake pressure light came on as normal, but when I turned the key, nothing. No clicks or dimming lights, just nothing. The car ran cool all day also while I was driving it, around 198. I waited an hour and tried again and it started. I checked the voltmeter and while starting it dropped clear into the red, so I thought maybe my battery was going bad, it seems on new cars when it goes, they do strange things. I bought the car used so I don't know how old the battery is, plus it was a delco and you had to tilt it to see the green dot. I had the battery tested and they said it was good, but I bought a new one anyways, I went up to the 900 amps. I tightened up the cables good when I put it back in, and now when I start it the voltmeter doesn't move nearly as much, it stays in the "good area" of the guage. The only other thing I can think of is the clutch switch stuck or something, does any one have any ideas, thanks.
Steve
