Tim81
Hello Again, Can anyone tell me if the stock strut rods are straight from end to end or does the end that attaches to the diff have a slight bend in it?
Thanks Tim
Thanks Tim
Thanks Tim
I believe the strut rods on 81 and 82s are different in design and geometry as compared to earlier C3s. The end caps that contain the bushings are not perpendicular to the shaft itself. Is this what you mean by a 'bend'?
Yes, I believe this is exactly what I mean. The rod itself looks straight , but the end that attaches to the diff does not line up with the rod itself, it looks like it is angled just a little. Both strut rods are exactly the same.
Thanks Tim
Strut rods are straight. If you have a bend in it, the rod is faulty and needs replacement.
Thanks Tim
...I think 82 (collectors?) have alu strud rods where 81's still have steel...
WOW this must be the alignment guys speical tricksFE7 only I believe.
NOT what you want:
