Stuck at 20 MPH
FlagCraig
Tennessee
2003 Anniversary Edition Coupe
1970 Corvette 350/300 has a speedometer issue.
Stopped working then went on and off for a bit now stays around 20 MPH when moving.
Going to trouble shoot. Should I start with replacing the cable?
Thanks.
You should check the cable first. Whether it needs to be replaced will depend on what you find.
:thumb
Cable guy
I had a very similar problem and changed cable and gear since I was in there. Fixed problem
