Stuck hood on 81
grampa
USA
1981, bright red
Seems the hood release will not work, does anyone know of a tool to release the clips holding hood or any way to get to the cable to manually release the hood?
All response's will be appreciated.
FIRST grandpa ~ Welcome to the Corvette Action Center Community ~
grandpa,
Under the hood at the base of the windshield up in the corner, feel around for a plug, it is about 3/4" or so in diameter, push the plug into the engine compartment, then take a screw driver and feel around until you can feel pressure, there is a square type opening in the opening mech, once you feel this move the screwdriver toward the fender, this releases the cable.
If the driverside is the only side to release, and if you can, reach the cross cable and pull on it to release the passengers side, if this doesn't work the passengers side is set up the same way as the driver side with the rubber plug ;)
Also, sometimes you can reach up under the dash and pull on the cable and release the hood.. good luck
Thanks for the info, will try it out in the am. Will let you know how I make out. Will try cable under the dash also. Again, thans.
Thanks Rare81, got the hood open. Dam that was a pain, my hands are not that slim to get in there. Much appreciated. Now to start working on clean up. Been sitting around for a long while. Again, thanks.
