thor1960
New member
Following a long winter of medical issues, I finally got the cover off my '81 last weekend. All winter the battery is kept indoors, the car is in an unheated garage. Topped off the battery with a charge. After checking all fluids and such put the battery in. Like an idiot, I hooked up the positive cable to the negative terminal. I touched the negative cable to the positive terminal, got a large spark. Touched it again, same result. Realized my mistake, flipped battery around. Connected the positive cable to positive terminal. Soon as I touched the negative cable to the negative terminal the horn started to blow. Each time I touched the negative the horn blew. It was around 9 pm and rather than anger the neighbors, I stopped. I'm still recovering from surgery and using a cane. Getting down under the car to unhook the horn is going to take a few minutes at least.
What do you think I burned out that is making the horn blow and what other damage might I have done?
