D
devilfish
Hello
I got the engine out, and im now ready to do my rebuild. So its time to shop from summit ( or other places ). I really need som feedback from you, as its not easy to change the parts when it arrives to sweden.
Im going to reuse the crank ( if it looks good ), rods with new bolts, hyper pistons etc etc..
My plan is rebuild my engine using the products below, all from summit with the part number on the left, please give some feedback.
FEM-CSMHP762-300 rebuild kit
ARP-134-6003 arp rod bolts
TFS-30400006 trick flow heads
ARP-134-5001 main bolt kit
ARP-100-9902 lube
CLO-9-3145 cam gear/chain
FLU-716242 damper
I already have the lt1intake conversion from John. Hooker headers. 1,6 rockers.
The block is cleaned and drilled 0.30.
The entire rotating assembly is going to be rebalanced.
Some stuff I dident found on summit is: ( could you help ? ).
ARP head bolts.
Valve covers that fit my 1,6 rockers
What kind of pushrods do I need?
A good head gasget that give me a good quense effect.
etc..
I hope you can give some tips.
Thanks..
ARP-100-9902 lube
FLU-716242 damper
ARP head bolts.
etc..
Thanks..
