OK, OK....... Wow, guess I asked for that.....:eyerole Looks like a repaint for the Thermo housing. Hoses are already in the bracket under the Alt, and the 5/8 hose is correctly positioned.
Got busy this afternoon...:bang
1. Redid the temp wire today with the correct clips.
2. Fixed the kink in the upper rad hose.
3. Welded in the center body mount brackets.
4. Replaced the m/c brake line and front left brake line junction block (first set leaked).
5. Bled the brakes again.
6. Cut off the upper rear shock bolts that I had put in the wrong direction and couldn't remove because the body was in the way. Put new bolts in the correct way.
Started it up and DROVE out of the garage for the first time in 20 months!
Pulled the E-brake and promptly broke the right side brake cable AGAIN!
![Head Bang :hb :hb](/data/assets/smilies/banghead.gif)
The little ball on the end popped off. Same thing it did the first time. I hope I can get LICS to replace it this time instead of repairing it like they did before.
Waiting for my new Bilstein HD shocks and substitute air cleaner to arrive. Still have to put the interior back together and a million other little things. Maybe tomorrow.....
OK, I'll get the correct tank cap!!!! Jeez......:W
Thanks guys.
