W
Willycool
Hello All:
For all of you who are looking into installing a front grille screen, I just wanted to share my personal experiences with you so you can make a confident choice in choosing a suitable material for your front grille project.
This is a very important decision because:
1) The grille material must be strong enough to protect the rad and condenser and deflect road debris impacts.
2) The grille must allow sufficient air flow, no less that 60%
3) The grille must be mounted securely or it could end up in your rad and cause damage.
4) The material must be maintenance free and look nice.
During my research into finding a suitable grille material for the C6, C5 and C4 I have discovered the following:
The 20 gage Stainless Steel round hole pattern with 79% open area stopped a rock and standard size bolt at 55 mph during testing with out damaging the grille.
The same gage mesh (20 gage) screen did not hold up so well and was damaged, causing the items to pass throw the mesh. The mesh began to fray and need to be replaced.
The 23 and higher gage mesh was destroyed and is not suitable.
I suggest that you do not go any thinner than a 20 gage and stay away from plain steel or aluminum because they will oxidize and need to be replaced. Be careful with painting the screen, because the paint will be bombarded with road partials and will come off.
A power coating would be more suitable than painting.
Make sure your grille material is secure. I suggest you do not use wire to secure your material to the plastic grille, because it could fatigue and break, causing the wire and grille material to strike the condenser and rad.
The 20 gage material actually strengthened the grille area, were lesser gage material did not.
I personally like the look of the round hole stainless steel, because it blends in nicely with the round head lights. The Stainless Steel is also maintenance free and can be polished to a mirror shine.
The matching side vent grilles are also nice.
If you have any questions, please send me a message.
looks cool
