Sun visor lights
Eureka, CA
2000 White Coupe
Can someone tell how to remove lights from the vanity mirrors on a 2000 Corvette. Both passenger and driver sun visor vanity lights went out at same time. Ideas on where to look if bulbs not the culprit.
dadaroo
Gone but not forgotten
Columbia, SC
2001 Convertibla, Navy Blue and Light Oak
I suspect Fuse 2 in the I/P fuse box. Common issue. If not that then test Relay 37 there or swap it with a known good one. If neither is the problem I can see if the FSM provides any guidance on removing the bulbs. If not bulbs then we'll have to look at further diagnostics.
Mr. Sam
Eureka, CA
2000 White Coupe
Thank you for the advice. I checked the #2 fuse under the hood but still need to look at fuse in passenger side fuse box.
dadaroo
Columbia, SC
WRONG. I said Fuse 2 in the I/P fuse box. That is in the passenger foot well.
