SUN VISOR REMOVAL REPLACEMENT
CHARLES
BOSSIER CITY LA.
1998 torch red coupe
I need some help on the removal of sunvisor, anyone out there know how this is done ??????????? Tired of scratching my head.
You have to unclip the visors and move them toward the door on the car, you will see a screwdriver type slot at the base of the Visor, Insert a screwdriver in that tab, hold the screwdriver in your left hand and the visor in your right, rotate visor and visor base counter - clockwise by moving the visor over to the drivers window position, the entire base will rotate. Pull out carefully and disconnect the electric tab for the lighted mirror.
