fulltilt
New member
Hi. I am new to the forum. I know Camaros and LT1's pretty well. I roadrace a 1994 Camaro. For that reason a shop I have worked with called me about an opportunity. It's (supposedly) a 1995 Supernatural 435 Camaro. The owner has had the engine rebuilt about 6000 miles ago, and has spent $9200 on the car in the last two years. Now the cooling fan relay allowed it to run hot and they suspect head gaskets. He thinks the guy may just want someone to make him an offer. The car is purple, doesn't have anything special about the body other than ground effects and vinyl letters under Camaro on the back that read Callaway Supernatural 435, has chrome aftermarket 5 spoke wheels, and in the engine compartment it says Callaway 400 or Honker 400, can't remember which of those went together. Also some aftermarket suspension components. They say it has Trick Flow heads, and the shop talked to Trick Flow and they said they were special heads made for Callaway. My questions are:
Does it all add up? I find VERY little info on anything Callaway Camaro that isn't a C8.
What may this car be worth if I fix it? It has 48,000 miles, an automatic, black leather in good shape.
What wheels would this have come with? Factory Z28? If the wheels are not correct, I think they should come off to make it right.
Looks to me like the Callaway Supernatural 400s were 383s. If that is correct, what would the 435 mean?
Any help would be appreciated greatly. Thanks!
