S
sscam69
I have a question cocerning the springs on my 79. what is the unsprung height of the springs. The reason that i ask is that there is about 3" or more spacing between the fender well and the tire. Mind you that the tires are 245/60r15's. The rear seems fine and just put in a composite spring.
New bushings from energy suspension was put in the rear and front. The mechanic tightened the arms with the car lifted leaving the A-arms in a hanging position. I told him that he needed to let the car down, loosen the arms and let it sit for a day so that it could set right. Well two days later he pulled out the shocks and with the arms loose pushed down on the front but the same height remained. He thinks that the springs are seated in the wrong place or they are not the orignal springs and might have to cut a few inches.
Can anybody help!
sscam69
Can anybody help!
sscam69
