USMC2531
I am considering upgrading to the sway bars on my 09 C6, I have the base suspension and I am looking at Eibach bars. Does anyone have any experience with them or upgrading the base bars to something else?
An acceptable compromise may be to install Z06 sway bars. I had a base suspension C5 and installed C5 Z06 bars and it made a difference in cornering. My car felt like it had less lean in the turns and was not any more harsh over bumps than with the original base sway bars.
I would almost bet money that C6 Z06 sway bars fit a base suspension C6.
Can anyone tell me why the Hotchkis Sport Suspensions Sway Bar comes with more compliant rubber bushings? Isn't this like 2 steps forward, and 1 back?![]()
Perhaps the Hotchkis bars come with the rubber bushings so that the buyer soesn't need to upgrade all of their suspension bushings to urethane.
It would seem to me that it WOULD be the "1 step back" that you speak of if only one part of the suspension had urethane bushings. It is also possible that urethane bushings in only one area might put added stresses on the rubber bushings elsewhere.
Pfadt C6 Z51 Poly Sway Bar Bushings
Replace your stock rubber bushings with our polyurethane bushings and enjoy the improved handling! Each kit includes two front and two rear bushings as well as urethane-specific lubricant.
With C5 and it's derivation, C6, GM did a clean sheet of paper suspension geometry. One goal was to get the car to handle well but also to allow the body to roll in the interests of using lower rate springs and bars. When you look at the C5/C6 toe and camber curves you'll see that GM was successful.
For cars which are not focused narrowly on motorosports such as road racing or competitive autocrossing, you neither need nor want big stabilizer bars. In a performance street environment, the performance increase with the reduced body roll will not be that great and the decrease in ride quality--especially the increase in "head toss" on roads of uneven surfaces side-to-side--will be noticable.
Fact, is the C5/C6es handle quite well inspite of some body roll. It's sorta like, if you're a weekend cruiser and not a road racer or slalom driver, having your cake and eating it, too.
That said...if you're a racer or you just like bone-jarring ride, then big springs and big bars are for you.
Regarding a 2009 C6 coupe w/ Z51.
If you're not a racer, or looking for a gratuitously hard ride, but you like to push the car on twisty roads, exit ramps and cloverleafs; what about a combination like the Pfadt C6 Z51 Poly Sway Bar Bushings #1110223, and either:
Bilstein Gas Pressure Sport Shocks or The C6 Johnny O'Connell Shocks?
As for the shock absorber change, I don't have experience with the two dampers you mentioned. I can tell you that exit ramps and cloverleafs are usually steady state cornering "events". A shock change will make little difference in the way the suspension works when the chassis is loaded in a steady-state cornering situation.
As for the twisty roads, it depends on how hard you drive. Your car has a built-in g-meter. When you're pushing the car on "twisty roads," if regularly drive the car like that and you're seeing lateral accelerations consistently above 0.5 to 0.7 g, then a damper upgrade might improve your car's handling and feel.
That said, if you don't want ride quality which is more stiff or harsh than you have now, I wouldn't change shocks unless...what you put on is adjustable or double adjustable. Adjustable shocks will allow you to sofen the ride when your not planning on driving hard but, when you ready to run the car hard through the twisties, you can jack the car up and change the shock valving.
All we hot rodders have the urge to change and personalize our cars, but reality is that the C5/C6 Z51 suspension is pretty darn good and, in the majority of cases, the only folks who need more roll stiffness or more aggressive damping are those who are using the car for motorsports or people who enjoy stiff and harsh riding cars.
