V
vmrod
What is the difference between a corvette water pump and a SBC short style water pump? It looks like the bolt pattern and center guide are different. Are there other differences?
black_81_vette said:The main difference is the regular passenger car pump has a 5/8 inch shaft where the vette uses a 3/4 inch diameter shaft.
vmrod said:That is kinda what I was thinking. I bought some SBC chrome pulleys for a short water pump. When I go to install it, I see the center hole needs to be larger. (drill, drill) That is done. Then I noticed that the bolt pattern was different. (drill, drill) Done.
I thought, if I was going to use an aftermarket pulley and modify it, why not just buy a new, chrome, short-style water pump (non-vette) and use a regular pulley?
