hzl6cm
Since my the tranny on my '04 Z06 is pretty notchy when cold I plan to convert to a synthetic transmission lube but wondering which one I should use and what experiences other people have had. I've used Redline MTL successfully on several cars in the past, including the 4-speed on my '70 Stingray. However later model GM manual trannys take Dextron III ATF - I didn't know if Redline synthetic ATF would work in a manual tranny or if something else would need to be used. A few years ago, when I had a similar problem with my '01 Camaro SS somebody on the F-body forums stated that the T56 was filled with synthetic fluid. However, I don't think that is correct since the sticker on the side of the tranny and the owners manual just say to use Dextron III ATF and don't say anything about a synthetic fluid. I've searched the forums and site and couldn't come up with any info on this issue. I've posted in the C5 section instead of just the Z06 since this issue would be applicable to any C5s. Thanks.
Kevin
Kevin
