An update on the issues and a question for Hib
Hi guys!
Just thought I would bring the thread up to speed with the issues my car is having.
Issue 1. Speakers in Delco Bose Gold squealing/not working... It turns out all my amplifiers were bad. In fact.. the front right speaker amp had experienced a "thermal event". It looked like it had gotten wet somehow at one time as the metal cover over the amp was covered with rust. Anyway, I sent all the amps to Doctor Don's and they did a fantastic job! Got the amps back in a week and now my radio is rockin again. If you have amplifier woes, I suggest Doctor Don's. Great Job!!!
Issue 2. SYS flashing. This is still happening. I still have the C41 and H41 code. I did do as Eccs suggested and tried to pull codes directly from the ECM and was successful. There were not any codes in the ECM. This error is not effecting driveability one bit, so I'm driving and enjoying my car and will worry about it this winter. I do have my FSM finally so Im not really that worried about it. When I do fix it I will update the thread with results.
Issue 3. Battery Drain... I just replaced my battery with another Die Hard gold. The battery had gone completely dead over the winter when I needed my charger for other reasons, and we all know what a bad thing a completely dead batter is. The battery would no longer hold a charge. This is probably the fifth battery I've put in the car so there is something going on here. As long as I drive the car on a regular basis its ok so thats what Im doing. This will be another winter project and I will update the thread when (if) I figure it out. I'm sure this will be a challenge.
Issue 4. FX3... Shocks feel softer than they did. Here is my question for Hib.
Hib, earlier in this thread you stated:
I will offer some guideance on the problems with SRC. Let me preface this by telling you that your car sometimes may "feel soft" because it
is soft. In 89 and 90, all cars which were ordered with both Z51 and FX3 were downgraded to the base springs and stab. bars. The downgrade is not widely known, even today, and back in 89-90 Chevrolet did not make its existence known to the public.
My question on this is that my car has the Z51 and FX3 and the FE7 and J55 RPO's. If my car has the FE7 RPO, then did the suspension still get downgraded? I would really hope not as Heavy Duty Suspension is checked off on the sheet. I'll be pissed if we didnt get it. Is there a way to verify if I did or did not get the HD suspension? My car dosent feel soft, just not as stiff as it used to be. The car's getting old, just like me
!! The shocks show no sign of leakage. They are going back to Bilstein for a rebuild this winter. The question... did I get FE7 and how do I tell? Stab. bar diameter perhaps?
This car rocks with the 6 spd and 3.33 rear end.
Thanks for all the help guys.. I will update the thread as I fix things!
P.S. I just replaced my Firehawk SZ 50's that I put on in 2001 with GS-D3's.. Man these tires are pissed off!!! Very agressive looking. Very agressive on my wallet too. I will need more seat time to evaluate them but so far, I think I like them. I believe the new sticky rubber might be accentuating the fact that my shocks arent as stiff as they used to be. Feels a little strange diving into corners really hard.
Thanks again and Save the Wave!
