Hi Jake! How's things?
Man have I done a lot to my car. New upper A frame bushings, new rag joint, two new serpentine belt pulleys, new serpentine belt, new auto-dimming rear view mirror, new sun visors, new header garnish, new rear deck trim, painted the rear speaker grills, new Bilstein shocks, new lower ball joints, the resistors, and today I'm going to remove the right door panel because the power window switch looks like it was pried off and it may have broken the door where it mounts but I have some really good two-part epoxy that you knead by hand which should fix that. Then tomorrow or the next day I am going to remove the radiator and remove tons of garbage it has sucked up. I also have to replace the coolant sensor someone broke. It is a lot of work but it is getting better all the time.
