I have a 1960 original 283cid with a T-10 4 speed. Code shows tranny to be a 69.
Does anyone know if the original size/type 10" 10 spline will work or do I go with the 69 clutch which is either a 10.5" or 11" 10 spline. The 60 clutch is the 3 finger type where as the 69 is the banjo type. The bell housing I believe is correct for the 60 as it has the starter mount on it.
