DWC, There are a few places were the T-Tops on an '82 can be adjusted. The first is at the front latch. About all you can do here is screw it in or out. Out will tighten it and in will loosen it. The second place is at the rear of the top. Here you loosen the 2 torx screws and adjust it in various directions to get a smooth latching feel. The last place to adjust is a little harder to get to, and a little harder to get right. Under the rods(I don't know what else to call them) where the tops slide in to the "T" there are shims, are at least there were at one time. Again you take shims out to tighten add to loosen..........I hope this helps.......Steve
