mcditalia
I eventually need to change my tach face. What is involved with this task and what is the easiest way to go about it?
Thanks,
MC
Thanks,
MC
vintagecorvette said:I would recommend that you hold the speedo shaft and wind the needle off counter clockwise. Do not pull, you chance breaking the shaft. Good luck. oWEN
JohnZ said:As soon as you replace the tach face and put it all back together, you'll wonder why you didn't change them all - the new tach face will really make the other five gauges look bad. :eyerole
