Tach in off position on a 82
jenkx
Michigan
My tachometer needle parks itself around 1500 rpm when I shut down the engine. Returns to normal when engine is turned on.
Is this something that I should be concerned about?
Thank you
Sent from my GT-N8013 using Tapatalk
as long as it works when the engine is running,I wouldn't worry about it.
:chuckle
Bill's right though. :thumb
FWIW- Mine will float up to around 800rpm when it is turned off. No big deal. I have validated with the car hooked up to a laptop during datalogging that the tach reported RPMs are pretty close to what is being reported by the ECM to the laptop.
:chuckle
x3..
Try this: Rev the engine to 2000 and shut it off.. Hangs at 2000.. Until you start it again. Not a worry.. :)
:w
Stefan
