crause
- Joined
- Sep 4, 2003
- Messages
- 266
- Location
- Louisiana
- Corvette
- 75 Convertible-steel blue / 2000 lt. pewter conv.
Have you done any work on the tach. in your C3? Mine has been doing some strange things and not sure where the problem is. I took the 75 out for a ride the other day,
after sitting for several weeks, and noticed that the tachometer was not working. The needle was pointing between and 15 and 20 and did not fluctuate with engine speed. No other problem and figured I would check the connection at the distributor later. I needed to change the oil so I took it out for a run this morning and when I got home I pulled it up on the ramps and waited for it to cool down to change the oil. A little later I went out and changed the oil and filter and lubed the frontend with no complications. Before I started it up I checked the wire plugs going into the distributor and made sure the tach wire and the power wire were tight and not cut or scuffed. Everything looked ok so I went to start the engine. It would turn over fine but would not start. Never had any trouble starting it before and was very confused. I checked the power wire to the dist. and it was getting power when I turned the ignition switch on. I unplugged the tach lead going into the dist. Turned the key and it started right up. What the?:confused I turned it off and plugged the tach lead back in and tried to start it again; would not start. Unplugged it and it started right up. Any suggestions? :W
