Tail lights for a 74?
flyboy3434
New member
Pensacola, Fl.
1974 Yellow Roadster
Could use some help on how to get the lenses off the tail light assemblies. On the 74 there are no screws holding the lenses on and I have tried to remove the chrome bezel by turning it but it is either frozen on or that's not the way you remove the lenses. Any help would be greatly appreciated! Jim
They come apart from the back side - -underneath the car. There are two speednuts that hold the housing halves together. Our 74's are an oddball year - -I don't think any of the other C-3's use the same design.
Regards-
CQRT is correct. They are quite a pain to get out. I couldn't tell if you were trying to replace the lense or simply replace the bulb. None the less, all you have to do is climb under the car and you will be able to see the bolts/screws. I also agree with CQRT about oddball, took me a good hour or so to figure out how to get them off the first time.
