Stingray74CC
Wow it's been a while since I've posted on here, but I am in need and I know I can always depend on the good people here at CACC.
Here's the story...
I had leaky carbs and every now and then I'd find gasoline pooled on my intake manifold. Apparently it got really bad and began leaking into my intake. I went to start the car and it turned over but didn't start. I tried again and WHAM nothing...tried one more time and the same thing. The starter tried to turned over the engine but couldn't do it. Great, gas in the cylinders. So today I took the carbs off, tighten all the connections, replaced the gaskets, and replace the fuel lines and blocks. Put everything back together and she started right up. That was a good feeling.
But here's the problem, I am now having a little tapping noise from what sounds like the number seven rocker. It speeds up when the rpms go up and slows down at idle. It made some noise before but nothing this loud. Did I bend a rod a little or just push the rocker out of place? Any ideas?
Thanks for the help,
Anthony
Here's the story...
Anthony
