ptuner11
60 vette.
Five retail sending units later, I have yet to find one that works correctly. I've sent the gauge and sending unit away to be calibrated....still doesn't work. I replaced the wires and connections...same thing. the needle after a few minutes flips over and pegs hot, but the engine isn't. Besides Delco, I've tried the Wells tu5 , which is touted to be a replacement...no work.
I tried a separate wire from the sending unit to the gauge directly, unhooking the old wire...no change, the needle flips to the hot side. I removed the gauge from the dash and set it up on my bench. I used my battery charger and ran the hot to the gauge. another wire from the other post on the gauge to the top to the sending unit. The negative from the charger to the base of the sending unit. I put the unit in hot water, careful not get the top of it wet. I used an IF heat gun and heated the water(and sending unit) to 180 degrees. I then loosen the small nuts that hold the coils on the gauge in place. I gently moved the coils to all conceivable positions. The needle either stayed on the cold side or abruptly pegged to the hot side, never getting the coils to 'balance' the needle in the middle. i tried all of the new sending units, including the Wells TU5. i just don't get it. i sent this gauge and sending unit to two 'reputable' gauge repair places, one in LA and one back east. they both sent it back saying the gauge is now calibrated, but the gauge still doesn't work.
thanks for any suggestions
ps i'm thinking one of the coils in the gauge is bad. How do I check for a defective coil?
