Hello,
Need to start troubleshooting the blend door motor after seeing a DTC code of 01. Issue is that my system appears to be stuck on (in) AC. Found that I can manually move the door to get the heat working. As soon as I change the temp the door will slide back the other way which is fine. When going back to 90 degrees no movement.
How difficult is it to replace these motors assuming that this is the problem? I still need to fully complete the circuit fault steps on 1C-7 in the manual. Plus find the pages on replacing the motor as well.
