Silverandblack
My 1977 vette runs well apart from this issue, the temperature guage when starting the engine from cold shows 220 degrees. Then goes up nearly in to the red after a few minutes, the temp guage and temp sender unit has been replaced along with a new covered wire to connect to the temp sender on the wiring loom.
The engine temperature when measured with a digital unit shows my engine, running at a modest 180 degrees. Therefore the problem I have been told, is that of a resistance problem in the wiring system. And I'm told not to worry about it.
However I find it difficult when stuck in traffic to watch the guage creep deep in to the red . Expecting the engine to crack at an moment, i have also put in a new fan and clutch and the cooling system has no leaks. I had the radiator recored too , but this temperature issue worries me due to the huge sum of money invested in my baby.
Peter
Peter
