fastglass95
Turbo-Hydramatic 400 transmission question:
1) On the drivers side of the case, about 1" above the pan flange, there is a wire harness type thing that plugs into the side of the case. What is it connected to? (wires) and What is it called? Mine is loose and appears to be contributing to a fluid leak, I assume these seal with some sort of "O"-ring?
I am replacing pan gasket and filter and noticed this, may want to repair the leak now, while pan is off. Looks like a plastic piece that pushes in and locks with locking tabs inside the case. From there, it has a white wire that goes to ?? and a brown wire that goes to a box only 1" away (inside case)
2) How do you correct the speedometer gears on a TH-400? Mine is out of a donor vehicle and reads about 7mph HIGH at 60 mph. Can this be done with the tranny in the car?
Haynes manual is of no help on this.
Thanks for any help.
Tom
Tom
