JonM
...you helped me out. I was having a battery drain problem. So I put my amp meter on all my fuses and found that my ctsy/clk fuse is drawing 3.36 amps with everything off. As we all know that fuse runs about 70% of everything in the car. I am thinking, I am going to have to rip into the dash and start disconnecting every light, horn, relay under there one at a time to make that meter drop to zero. Then I remember reading a battery drain post answered by Ken about his car and how his "Storage Compartment" lamp was his cause. So this was the first place I looked and disconnected the leads running to the lamp. Sure enough the amp meter drops to zero. On closer examanation I notice their is no switch located where the pin on the compartment door comes down to shut off the light. :duh Anywhy. its all fixed thanks to the "Crazy Man" in CA. If you were here, I would give you a hug Ken.
But seeing as you are so far away...I'll give you one of these. :BOW
