Mark, the red cans seen in the above photo, are not gas cans, they are empty dog biscuit pails, that I use to recycle steel and aluminum during my work.
As for the engine in the upcoming build, there is no way I can afford to purchase a 572 for my own use, so I have decided to build my own Big Block. I have just purchased the latest gen IV 540 ci BowTie block from the General # 25534363, and I am in the process of sourcing all the necessary parts in order to get ready for assembly.
The engine will be mated to a Tremec TKO 600, using a HD clutch, a Lakewood scattershield, and coupled to the rear curtesy of " Dynotech " shafts ( 3 ), and a Dana 44.
The figures in the graph have just been recieved from my engine builder, and during the past ten years, his projections have never been off by more then 2 to 3 %, once the engine is hooked up to the engine dyno. This should turn out to be a very interesting build.
Check closely the two columns that I have circled in the graph, and consider these specs as using only using normal aspiration. I am still considering the use of " Procharger, to run it up 10 to 12 lbs of boost, and if I do, it should put me into the four figures.
Really looking forward to this build.
Stepinwolf
P.S. Once again a big thank you to all who have responded to my post, and commented on my work, It means a lot coming from you people.
