The FattDaddy Frame Saver From CCA
Willfulone
VA
2004 CE Coupe
Custom Corvette Accessories is proud to present
The "FattDaddy"​
The "FattDaddy" was designed and engineered by Custom Corvette Accessories with strength in mind. The "FattDaddy" uses grade 5 bolts and has and 1 7/8 inch polyurethane wheel that can withstand up to 800 pounds of operating pressure and 1200 pounds of static load.
The "FattDaddy" is a single wheel front clip frame saver that inserts through a 3/8 inch hole you drill in the frame. The "FattDaddy" distributes its load via a grade 5 bolt and a 1/4 aluminum rig, giving you the ultimate in peace of mind and protection for your Corvette frame.
If you are tired of that horrific scraping sound every time you back out of the driveway or go over a speed bump, you can protect your front clip from frame damage like this with the "FattDaddy" .
In our short but steadfast tradition of "Killing the Corvette Tax, one product at a time" We are thrilled to offer the "FattDaddy" at an introductory price of, not $99, not $79, not even $59 on sale, but...
CCA Priced at​
$44
Please visit our web site at www.CustomCorvetteAccessories.com and click on the "FattDaddy" link to take advantage of our introductory offer!
Peace
Chip
Will this work on the C4? 84' to 96' has a similar rail under the front like the C5.
How much rail is exposed. If you can tell me how much space there is above the rail, how long the rail is and how wide it is...
That should be enough info to determine.
Peace
Chip
We test fit a set on a C4 last Saturday at a test and tune, and they fit...
Peace
Chip
those wheels are worth it
