T
tazdevl35
After 14 monthes and a lot of time and money, I got her running today! Even with stale gas the power is obvious. 30 minute cam breakin at 2000 rpm and a few carb adjustments along with a few repaired vacuum leaks and she's breathing serious fire. In gear, light power break it shreads the tires and barks out the exhaust. Even the valve adjust was perfect first time. UNREAL POWER! Tomorrow I will drive it and see if there are any carb tweaks that will need to be made. I set timing at 10 degrees before tdc and the the total advance is 36 degrees. All the computer stuff works perfect and there was NO check engine light. It never came on once. After tune in and one more emissions check next month, it will be eligable for antique tags. Then I will put on the Super comp Chrome headers and side pipes. It should sound kick butt.Question is where can I put the O2 sensor when I put the headers on? I have a NOS 125 power shot plate setup to put on it after the headers and pipes go on it. The I will be going after the C6's and the big block cars too! Oh by the way, even with the computer distributor and carb, in spite of 268h comp cams, the idle is fantastic at all times(start up hot soak and restart hot and cold idle etc.) Steady and strong! And It idles at 700 In drive to boot. L81's kick ass...no doubt.
Now, Its beer thirty!
Taz :booty
Taz :booty
