toobroketoretire
Banned
As some of you old timers may remember the '55 thru 57's didn't use a crossmember under the tail of the transmission. Instead the engine had mounts on the FRONT of the block and on each side of the cast iron bellhousing so the transmission literally hung from the rear of the engine. As the transmission was hung the rear of the block had 7 bolt holes (the 7th being at the top/center). Starting in '58 crossmembers started being used so the 7th hole was no longer needed but (I think) the engine blocks still had that 7th hole up until the big blocks and 350's. Do any of you old timers know for sure when that 7th bolt hole was finally eliminated?
