C
CharlesBrown
Thought the following was...interesting!
Truth About Ignition Wire Conductors
Misrouted wires can cause BIG problems - GM HE ignition is just LOOKING for a way out, and if misrouted, as in, NOT in the original SP wire looms, and near something else metal, the wires CAN emit EMI - electro-magnetic interference - same as a nuke, and this can cause false codes from solid-state sensors, ESPECIALLY ABS module, and some codes which DON'T light SES. Ask me how I know that read it in FSM by chance after chasing a false code for almost 10 weeks in '08 yup UH huh YIKES.
The subsequent misfire COULD account for high HC count, lower exhaust, higher NOx count. That's a stretch tho'...
I AIN'T puting Motorcraft or Mopar wires on MY Vette!Go to a NHRA NAtional event where 100's of thousands of dollars are on the line and look at what they are using for Ignition.
It starts with a M but not Magnecore.
Hib, do you have any info about the Magnecor product, pro or con, that you would be willing to share? I'm curious if you've researched their products, and how they compare with OEM equipment as well as other aftermarket ignition products.
Thanks,
Andy Anderson
I used the Taylor braided stainless steel and they fit nicely on my 84. Look very good too. They dont list as an application but they do fit well. Same size as the ones Josh mentioned? I wonder
When I replaced the O.E.M. Delco/Packard wires on my '92, I went with the 7mm. Belden Premium Super Blue Ignition Wires from NAPA Auto Stores.
