Man, what a post. It started over 3 1/2 years ago and people are still debating the subject.
No kidding...it's the energizer bunny post, it just keeps going and going and going...
:L
Ok...although I'm a newby....I just bought a C4 (1994) and have the good fortune of having Hypertech here in Memphis. They did a reprogram for me, and gave me a Hypertech 160 degree thermostat....said the program lowers the temp of the engine....it was running what I thought was hot at 225-230, but a mechanic friend said it was designed to run that hot. Since the Hypertech tune, it DOES run very well with the 160....my two cents anyway.....
that is correct and with a lower temp thermo your car may not pass you states emission testsI'm no expert on this subject but for late model Vettes with electronically controlled fuel injection - changing thermostats to something other than OEM spec can have some ugly results. Lowering the thermostat temp will cause the computer to richen the fuel mixture. This of course will result in reduced fuel milage and over the long haul could do some cylinder damage. The C4's and especially the C5's were designed to run at mucher higher temperatures than most folks are accustomed too. Stick with the factory recommended thermostat and stop all this hand wringing.
Remo:cool
Should we revive an oil filter post ?
Glenn
Exactalackaly Right Bill!! Your engine will run Better,Cleaner,More Economically and Environmentally Friendly!!I say keep it with what the GM Engineers reccomend. I figure they know more about it than I do and I am pretty much a stickler for OEM reccomendations; designed that way for a reason in my opinion!
Bill
Keep your GM car,ALL GM!!
