This one is SWEET - and for sale...
*89x2*
CallawayOwnersGroup.com
WOW! :cool
[FONT=Verdana, Arial, Helvetica, sans-serif]Vehicle Description [/FONT]
1994 CALLAWAY SUPERNATURAL 400 IMPALA SS. 12,000 original miles! This is one of only 30 Impalas between 1994-1996 known to have been factory tuned by CALLAWAY. The car was bought new on 5/9/94 for the purchase price of $25088.48. It was then taken to CALLAWAY on 10/13/95 to have the SUPERNATURAL 400 package installed. This package cost $24857.00. That's right this is a 50K muscle car. Capable of 0-60 in 5.5 sec.1/4 mile time of 14.1 sec at 100.mph, and a top speed of 156 mph. All this from a 4200 lbs. sedan that seats 5 adults in comfort. This is a 12,000 mile original car with all factory paper work, purchase invoice, owners manuals/CD, pre-delivery paperwork. CALLAWAY paper work includes owners folder with invoice, letter from Reeves Callaway, dyno sheet for the motor , and option price list. The Impala is black with a grey leather interior. Power windows, locks, seats, cold A/C, cruise control, tilt column, sunroof, AM/FM/CD player. Car is in overall excellent condition. It does have slight paint delamination on the top of the grill, but the grill is molded black ,so it is not an eye sore. It could be re-painted or replaced, but I wanted to keep it as original as possible. Car has a few small dings and scratches from over the years, but it is still show worthy. The CALLAWAY SUPERNATURAL 400 package consisted of a 383 motor ($12,675.00) This is a completely new engine retaining little more than the original LT1 cylinder block, which has been changed from a 2-bolt main bearing to a 4-bolt forged main bearing caps. Cylinders have been honed .030 inches over stock. A 3.750 inch stroke 5140 steel forged crankshaft has been added in increase displacement to 383 in. Connecting rods are forged 4340 steel,5.850 inches long. Pistons are likewise forged from low expansion, high silicon alloy. All this adds up to a GM small block that is as strong as a good racing engine. The heads are CNC machined to achieve the maximum size and smoothest flow in both intake and exhaust ports. Compression is a modest 10.5:1. Throttle body is increased to 52mm. Roller camshaft with larger stainless steel valves are added with a three angle valve job. All engine electronics have been reprogrammed for trouble free performance ($540.00). Mobile 1 full synthetic oil 15w50 is recommended for this engine package. This motor was dynoed at 400h.p with 400 foot pounds of torque at 5250 rpms. The dyno sheet is included with the CALLAWAY paperwork. Honker SS enhanced air intake with K&N reusable filter ($458.00). SuperNatural SS exhaust ($1270.00) 2.5" mandrel bent stainless steel dual exhaust with cross over pipe and straight through mufflers. BREMBO SS brakes ($3995.00) 13.1" diameter nodular iron pillar vented and cross drilled rotors with 4-piston calipers and stainless steel braided brake lines. Eibach springs and Koni adjustable shocks ($1014.00). Lightweight ForgeLine forged aluminum wheels with BFG Comp T/A tires ($4,001.00) 9.5"x17" fronts with 11"x17" rears. BFG Comp T/A tires 275/40ZR17 front, 315/35ZR17 rears. Vehicle Speed Digital Ratio Controller ($418.00) correct speedometer and PCM inputs with the low profile tires. VDO 270 Tach ($424.00). All this adds up to one well built super car. This will be the Yenko or Baldwin Motion of the future. Same principles modify factory cars to super cars!! Again this is car is all original including the BFG Comp T/A tires. This car has been service regularly with Mobil 1 fluids and filters.This car is sold with no warranty and has a clean title. The car is available for inspection. Any questions call # 859-402-0688 or # 502-542-0721
http://cgi.ebay.com/ebaymotors/Chev...69QQihZ015QQcategoryZ6169QQrdZ1QQcmdZViewItem
