Retroguy
Has anyone performed this Throttle Body Coolant Bypass Mod? The mod where you disconnect the small rubber coolant lines running to and from the bottom of the T.B. in order to no longer heat up the T.B. for very cold weather driving (whew! that's a lot to say). I'm learning about this mod which can be done for cars driving in milder weather, like southern Ca or Florida. It has no negative effect on mild weather driving cars, and many say the benefits are that there's no danger of coolant leaks that could work their way down to the touchy optispark and it's better to have cooler air in the T.B. than warm air.
